-50%
-50% Baskets Nike Air Huarache Runner
69.99 € 139.99 €
 Cooling problems
Radu
Nombre de messages : 2
Vos autos : renault 25 2.0 ts
Cooling problems Empty
MessageSujet: Cooling problems   Cooling problems EmptyDim 18 Aoû - 13:42
Hello everyone!
My name is Radu and I salute you from Romania Smile !
First of all, I'm sorry for typing in english because I don't know very much french but you could answer to me using google translate  http://translate.google.com/#fr/ro/ if you don't know english.
I have a R25 TS from 1986 for about 6 years now and I love it despite she makes me angry sometimes.
The problem is that the water isn't getting in the engine and it is overheating to the point of boiling. I've changed the water pump and the thermostat recently (new ones, of course), changed the water, cleaned the radiator, hoses and the expansion vessel. The water is rising to the second to last line where the ventilator should start but it keeps rising Shit . If I rise the expansion vessel water gets in the engine and it cools it, barely. If I put the exp. vessel back in his place and start the engine, whole water gets back in the vessel.
I suspect the water pump, but it is not possible to work just for 2 months or so Mad .
What's the problem?
Thank you!
Nombre de messages : 7466
MessageSujet: Re: Cooling problems   Cooling problems EmptyDim 18 Aoû - 19:54
scratch traduction please lol!
MessageSujet: Re: Cooling problems   Cooling problems EmptyDim 18 Aoû - 20:31
Traduction automatique Mr. Green
Bonjour tout le monde!
Mon nom est Radu et je vous salue du Sourire de Roumanie!
Tout d'abord, je suis désolé de taper en anglais parce que je ne connais pas beaucoup de français mais vous pourriez me répondre à l'utilisation Google traduit http: // translate.google.com / * fr/ro/si vous ne savez(connaissez) pas d'anglais.
J'ai un R25 TS de 1986 pendant environ 6 ans maintenant et je l'aime malgré elle me rend fâché parfois.
Le problème est que l'eau n'entre(ne rentre) pas au moteur et il surchauffe au point de bouillonnement. J'ai changé la pompe à eau et le thermostat récemment (de nouveaux, bien sûr), ai changé l'eau, ai nettoyé le radiateur, des tuyaux et le navire d'expansion. L'eau monte au deuxième à durer la ligne où le ventilateur devrait commencer mais il continue à monter la Merde. Si je me lève l'eau de navire d'expansion entre au moteur et il le refroidit, à peine. Si j'ai remis le navire d'exportation à sa place et le début le moteur, l'eau entière revient dans le navire.
Je soupçonne la pompe à eau, mais il n'est pas possible de marcher juste pendant 2 mois environ Fous.
Quel est le problème ?
Merci!
MessageSujet: Re: Cooling problems   Cooling problems EmptyDim 18 Aoû - 20:34
Hello,
It is necessary verified if some water is repulsed(repressed) in the vase of expension by the durit girl.
Checked(Controlled) if the radiator is hot everywhere.
Checked(Controlled) if both durit of the heating are hot.
Cordially
roadrunner-55
roadrunner-55
Nombre de messages : 4461
MessageSujet: Re: Cooling problems   Cooling problems EmptyDim 18 Aoû - 23:48
sonde radiateur.
j'ai eu ca avec la saf....
et la 25 ts se purge avec le bocal accroché en hauteur, et ne pas oublier la purge sur le carburateur
Radu
MessageSujet: Re: Cooling problems   Cooling problems EmptyLun 19 Aoû - 5:36
I'm not a native english, I try to do my best :519:
Nevermind, thank you all for answering. I think I found the problem, the thermostat bulb is broken. Tomorrow I will order a new one. I'll let you know what I solved after 2-3 days.
Stay tuned!
Have a nice day!
Cooling problems
» 2 problems sur mon GTD ph 1
